Just a quick update.
I am well into assembling the fuse, motor is on, servos and radio in, tail feathers on and those linkages made. I am adding 1/4" to the motor standoffs as the EME60 carb is right at the firewall with the included standoffs which incidentally produce the exact firewall to prop washer distance listed in the instructions. I am hoping to "cheat" the cowl just a tick out from the standard position.
I have not been flying for a couple weeks now due to weather here in Concord, NC and this weekend is looking great so I will take a day or so away from the P47 to prevent a total meltdown of my thought generator. I expect by Sunday evening I will be urgently getting back to the warbird!
| The elevators come already hinged (left) but I had to glue the horizontal stabilizers to the fuse with two aluminum tubes for strength. The Robart retractable tail wheel (right) went in easy but I tensioned the pull-pull cable with the wheel retracted. Wrong! I was able to turn the servo around and adjust the cables and all was fine. Click images to enlarge |
