Here you go, I did two canopies in just under 25 minutes. It's only as hard as you make it. I know lots of people tend to make things a lot harder than they are, so hopefully this will help those of you that say things like "the loose canopy is a deal breaker". It's so simple.....
Done this way it also does not have any fasteners, it is removable in case it needs to be replaced. If you want to go further you can install a 1/2" wide strip of Ultracote on the front lip and have it hang over onto the leading edge of the canopy shell itself......it will stick, just use the lowest heat setting for ultracote.
