Looks great Terry!
Jetpainter said
The name of the product is Spies Hecker Raderal Spray Polyester 3508. If you need any more info, let me know.
Fibertech said
Terry, I emailed you a copy of Nasons tech sheet for the epoxy.Terryscustom said
I have never shot Epoxy primer before and I need to shoot some on my canopy plug. I got the Nason 491-16.
Any recommendations on cure time before I do a little touch-up sanding? I'm told I need to sand laterally with 340 grit to create small scratches to help the air escape, which make perfect sense.
Also I have two options for guns and tips, I have a Devillbiss HVLP with a 1.0 tip (my typical top coat gun) and a Sata HVLP with a 1.4 tip that I have never used.
SWEET, thanks!!!Jetpainter said One other thing, make sure you let the epoxy sit for a minimum of 30 minutes after you mix before you spray it. Longer if it's cool in the shop. The induction period is important to that style of epoxy.
