sorry Terry read most of the build thread again up to page 66 but could not find any info on the size of the ailerons, elevator and the rudder cut outs. Is there a drawing showing the layout of the wing ailerons and servo boxes and the same for the stabilizer, and rudder. thanks again.
I will send to you but should be in one of boxsI will need this to
Not a fast builder just busy putting a check sheet together with the corresponding thread number to the particular build section so that when i build the plane i will have all the info on hand. Building will be doen this comming winter.
Like the clarification, thanks for keeping things simple!The plane is not designed to accommodate canisters or pipes sorry. The ARF will but the kit version is built for super light K.I.S.S. fun.
