White rose brakes
Mikeq;13596 wrote: Now you're talking...Once the fire has started it will grow until FG is nothing but faded memories ....
FG? FG??????? Faded memories of FG? What in the world are you talking about? Never heard of it. What does it do? Can it draw friends closer together? Can it make new friends out of acquaintances? Can it.....(You should have known this was coming)..... can it....."SNAPASAURUS"?
I got a chance to try out the set of wheels and brakes that I ordered from Vern and all I can say is AWESOME! Vern's products along with the service are top notch! Anyone even thinking about buying from Vern should just do it. The prices are a little high, but so is the quality. Thanks Vern
parapup;14886 wrote: I got a chance to try out the set of wheels and brakes that I ordered from Vern and all I can say is AWESOME! Vern's products along with the service are top notch! Anyone even thinking about buying from Vern should just do it. The prices are a little high, but so is the quality. Thanks Vern
+1
Chumley
Knife Edge;19605 wrote: How does one activate the brake? Is it through a switch on the Radio?
They don't work that way. There is an adjustment screw to adjust the amount of drag on the wheels. They aren't made to stop the plane, just keep the taxi speed under control on pavement.
the brakes are constant friction, so that you set the tension of the pads on the disc, have to be careful not to put too much tension or the airplane can nose over or place too much strain on your landing gear. takes some testing to get used to.
