The torque value of a coreless may seem significantly higher, but in reality it is a true myth. I say true, because they are rated higher, but the myth is really not a myth in reality. A coreless starts running up to operating speed at the instant it gets a signal from the transmitted input. It uses power to "ramp" up...then becomes constant until it reaches the end of its travel. So in essence, "example", a 486 oz. HS 7950 is only 486 oz. after it ramps up to it. But does retain the torque while input is being fed. However they are comparatively more economical. A brushless on the other hand is almost instantly constant speed and torque from the time it gets the signal until it reaches its e.o.t. The holding force never changes and remains as such until the signal is relaxed. So...a 350 oz. servo is 350 oz. throughout its entire range of motion. In retrospect, they are a little hungrier than a coreless, but because they ramp so quickly, the amount of mah useage is about the same.Question. Why do coreless motors seem to have better torque values over brushless motors? I guess brushless advantage is only "longevity" in the motor?
Also polling responses.....What do you guys think is a better motor for HV set ups....Coreless or brushless?
As for your second question Kelly, I only own coreless. I have not had the pleasure of owning any brushless as of yet. However I would like @Xpress to send me some so I can try them out.
From the people that have used the brushless, they seem to get awesome reviews. However, they are considerably more expensive than a coreless servo. Example: HS7980, 611 oz. @ 7.4 volt. ($145.00) HS9380 472 oz. @ 7.4 volts. ($180.00)
