Hello Primo, how are you?
I wanted to ask you for some advice, is there any way I can email you?
My email is [email protected]
for some reason, here on GSN, there is no button whereby I can send you a PM. However, for other people, there is. I am trying to learn to see if I am doing something wrong, or I cannot find a way to send others PM.
Hey Cam,
On GSN the PM is called Conversations. Click on your name at the top right of the page and click on conversations in the drop down menu. Then hit "Start New Conversation". There will be a box at the top when you can type in rollerman. But this only works if that person has enabled conversations in their profile. Hope this helps?
Hello Primo, I need to ask you a several questions on building this beautiful airplane...
1st question,
Are you using canisters or tuned pipes?
If so, did you install them first, before you glued on the belly pan?
OK, I owe you guys and update, so here it is.
With a little luck I will be maiden it Saturday or Sunday weather pending.
Now the SWB engine mount is on correctly LOL!!! Engine and exhaust are in place throttle servo and choke servo in place and working perfectly. For the tail wheel I made a piece out of carbon fiber and added some BLING BLING on it.
@ROLLERMAN , hello Primo, where did you order the pushrods from, for the throttle. I like this idea, since it keeps the servo away from the heat of the canopy. And those pushrods look stout!
It's sullivan Gold-N-Rod 4-40 S517 or S518. It's the highest strength push rod they still make. The carbon filled used to be the best... until they decided not to make it anymore.
http://sullivanproducts.com/GoldnRodMainFrame.htm
The catch is with the black rod is that it's pretty rigid and takes 440 hardware. I've started to use the blue semi-flexible 506/507 rod for throttle. Do not use red!!
