3dhs 89 slick
wedoitall
Member
Humberto do you have any advice on the best way to fix this. got alil to low on a deathslide and tig'd the corner the elevator. was lucky I didn't cartwheel.
wedoitall
Member
Can you show a little more of the plane?
yea sorry about that. I think I have it fixed. just needs a patch covering. I have never tried my hand at covering but im sure ill be pretty bad at it. Im gonna use white duct tape until then.
I wanted to keep it pretty light so I used balsa, CA and alil bit of epoxy on the repaired ribs. Seems pretty strong. That's why I already used a 15" prop instead of a 14, especially after I switch from a 85mg to 5245 on the elevator.
Cmala
I see where this one goes but is it necessary? ImageUploadedByTapatalk1374895223.133820.jpg
Cmala
Those look like the ending of the canister tunnel. I'll add a pic of mine in a few mins
Cool thanks
89 slick / DA 60 / not sure on muffler but no can, HS7950's.
pull pull or push pull rudder?
And I only need one servo per control surface right? Ail, ail, elev half, elev Half, rudder, throttle
6 servos.... Correct?
What's the best muffler?
