60" Laser-EXP
It is the same stick movements, just opposite.
Up line.
Right roll
Outside snap (sticks to the outside opposite corners)
Move the right stick from the upper right corner towards the upper left to flatten it out.
Recover however you like.
Ohio AV8TOR
Just Do It
Laser seems to handle the wind very well. Not the strongest wind that we fly in here in Texas today (8-9) but it has been unusually calm since my maiden. Hovering drift was all that was noticeable. Even slow flight for landing was pretty much unaffected. I am still all :eek:
Santi8
Thanks to Santi, I now have some 16x8's and another 300+watts *fist pumps
Über power!
Out of all the electric setups I've ever used, the motrolfly 4315-480 on 6s spinning a 16x8 has been the best, most powerful, efficient, and downright awesome setup to date! I cleared out almost my entire fleet, but may end up with a red laser for next season just because I love that power system so much and the looks of that Leo laser!
Enjoy the xoars!
Santi8
What kind of numbers are you getting with the DM4315-480 on 6s with the 16x8. APC-E or wood (insert brand) prop?
If I remember correctly I would push just over 70 amps and over 1700w on a fresh pack with a xoar 16x8.. the apc actually pulled less due to the flex at the tips. I have heard of others pushing higher with better batteries, but this is only on ground tests and with fresh batteries. In the air, you would never need that much power! Some set a throttle curve, others just use throttle mgmt.
