I am sure you guy's understand why I am taking so much time to get things sorted out before cutting wood. The base shape I laid out yesterday is based on the full scale pics at the kit size of an 80" fuse. I checked the formers against the projected images and here is where it stands. All the formers are correct in height but not in width, the final shape depends on these formers. Starting at the nose, pic one, the forward fuse formers are good below the thrust line but the top section need to be widened. I traced the cowl from a pic but exaggerated the inward curve for measuring purposes, pic two, the arrows point to what I needed for referencing and the black lines represent how it should be. Back to pic one, looking at the rear formers the arrows denote how they need to be widened. I will split them and adjust to position which brings up the next pic number 3. I have put two pieces of balsa the correct size of the stringer in a slot on the former, with the former square on the table and the square against the stringer. The stringer gives me the distance the base hardwood spar will need to be as the covering should protrude out at the balsa stringer compared to the thrust line stringer. Pic 4, the 1/4" on the table running along the outside shape line represents the thrust line stringer and has a 1/8" mark, this is where the formers will be widened to.
  I think, and I won't hold my breath, but I  think I am ready to start cutting something.
