Thank you Jet.
Trimmed the wide ends off of the trailing link tube. The plans show smashing the tube to form flat area for the upper joint, the tubing used didn't want to bend easily really was not sure the flatten area would match the lower bend so a trunnion use make just like main strut, this was silver soldered into the tube, the flat side was shimmed with a 3/32" spacer while soldering which was amount removed from each side of the 3/8" round bar used to form the trunnion. The lower 1/8" tab was shimmed 1/8" while soldering. The upper and lower holes should be in correct alignment.
