3D 50% cap 232
That's bad ass right there!!
Dooinit
The fuselage weighs 4 pounds 4.1 ounces. It's 95% glued here is a picture of the stress test. I weigh 189 pounds. And yes the fuselage is still in one piece.
Come on man....JUMP!!!!! I have faith. Super cool build. I will be watching.
Flyrcjoe
Joe, What ply are you using on most of the fuse?
90% of it is light ply. Then I have some 1/8 inch burch and 1 piece of 1/4 inch burch ply for the landing gear plate and F1. I know it is heavy in those spots but one of the places I fly has sprinklers that love to take out gear.
Question to you... As a builder I am curious to know the fuselage weight of the 55% extra that is in your avitar picture. Did you happen to weigh it before putting the turtle deck and belly pan on? I am wanting to compare weight of a 3/8 balsa stick build vs ply.
Flyrcjoe
Wow. I like that Cap a lot. You called it a custom? One-off? Impressive.
That plane was started over 20 years ago by York, John and a few other guys. They built the plug and laid up 2 fuselages, 2 cowlings, 1 elevator and stab and 1 set of wings but only 1 aileron. The only plug still around is the wing. I bought one fuselage and cowling set in the raw form from my friend Dan. I then built a new set of foam wings, elevators and rudder to save weight. When I finished it the final weight was 36 lbs 9 oz.
Can't find my weights. But... Bob Sawyer's came in at 4# 4.3oz at this point.
