Covering questions
Flyingjon
I have been working up the nerve to do a recover job on my 91" extra. The covering isn't too bad but I'm wanting a different scheme.
Does someone have a good estimate of how many rolls of Ultracote it would take to do a bird this size? My rough estimate would be five to six 78" rolls.
I'm looking for any tips on doing this job so fire away with your techniques, tricks, and help. I understand you want to cover back to front and bottom to top and to fill in the tight corners and curves with smaller pieces first.
I'm going to do a simple scheme in two colors probably, with maybe a few small stripes in a third color.
Any help is appreciated.
Basically you said it all. When I covered my 30% plane I used a roll and half of covering from value hobbies that are 15' each. Getting ready to start a recover on a 33% edge next week. Started pulling parts off of it this morning.
Flyingjon
You should show the progress here in this thread. Give me something to look at. [emoji106]
kork
I am no expert but have done enough to know what doesn't work.
My advice would be to use Ultracote for your first covering job. It lays down and works better on radius edges and will shrink up nice.
When you lay over another piece use really low heat and you will end up with no wrinkles.
I use Tracing paper when making templates. Its is a semi transparent paper so you can see through.
Cutting on glass works well to and will save on Exacto blades.
Try using a soldering iron with a sharp point for burning out hinge pin holes or fir cutting out areas.
I covered this fuse yesterday and look to wrap up everything else today watching some NFL playoffs.
The plane is a 100cc EMHW ultimate.
Key to covering is to know what your scheme is before doing anything
and try to limit how much overlaying you do to limit air bubbles.
Last thing.. You only need a sock when using dark colors. It saves on scratching but takes twice as long.
Have fun.
yakken
Have fun.
Did you cover the cowl?
