Next up was to start to get the stab fit to the fuse and get a relief made for the elevator control horn. Boy this turned out to be fun! But I definitely think it was worth the hassle!
In order to have enough room between the fuse sides for the horn I ended up having to move the stab forward in the fuse, basically butting it right up the rear turtle deck bulkhead, this moved the stab forward just over 1/2 of an inch. To accomplish this I had to remove the filler block without totally destroying the last bulkhead, which I managed to do barely.
Filler block removed and stab pushed forward over 1/2 inch to allow the relief cut to be made for the elevator horn. The Fin and rudder are just pinned in position.
I then cleaned up the filler block and pinned it back in place, I should be able to use the same block but I've decided to not glue it back on until I glue the stab in place.
After I got the stab moved forward and the relief figured out I started on an access hatch to allow me to get into the horn when the airplane it finished for inspection and maintenance.
Now it's time for the tailwheel block, and as I'm looking at this picture I realize that I have stringers that are not of equal length...... Guess I know what the first task tomorrow is!
Tailwheel on and the tail pinned together, Finally the thing will sit completely on landing gear and no boxes! lol
Better looks at the joiner and control horn. Once I glue the tail on I will put a filler block to take up some space between the joiner/horn assembly and the rudder post. If I ever have to replace the horn or the joiner, that filler block would have to be cut out, but lets hope that never happens!
Elevator horn Access hatch finished, I may counter sink those screw holes and use flush head screws but we'll see, it is made of an awfully thin piece of mahogany.
Hatch removed to see the horn. I will put a piece of sheet balsa between the stingers on the other side of the fuse with a small hole drilled in it at just the right spot so that I can get an allen wrench on the bolt head.
