I've spent the last few evenings working on the wing drawings. I changed the shape of wing tip to a more round shape, as that is the best I can come up with judging from pictures and dad's memory of grampa's. The original plans depict more of a Bucker type shape, and I don't think my tips are "scale" but again I'm trying to copy grampa.
I've got one side drawn. The wings are exactly the same top and bottom, the only differences are the bottom wing has grooved blocks for the landing gear and the servos for the ailerons, while the top wing has the cabane mounts. Therefore I'm just drawing one wing and the LEFT side depicts the BOTTOM wing while the RIGHT side depicts the TOP wing.
For the most part I'm sticking with the original construction. The original plans call for six, 1/4" square balsa spars. I'm changing that to 1/4" square basswood spars. I'm also changing the ribs from 3/32" balsa to 1/8" balsa with lightening holes, and the sheeting from 1/16" to 3/32". The wing tips will be laminated from Five 1/16" laminates. The ailerons will be cut free after most of the wing construction is finished and will be of the single bevel type with Klett style hinges.
The ribs in the center section will be made from 1/8" lite ply, with the ribs that support the landing gear and cabanes laminated to 1/4". The servos will be mounted in the wing on their side and attached to the plywood hatches so they will be easily removed for maintenance.
