Well, I'm coming down the back stretch now! I have the cowl cut, the tail brace wire bottom bracket made, throttle push cable in, and I have spent god knows how many hours trying to come up with more things to do before covering and there just isn't much.
So with just some sanding and small details to finish, the Koverall should be here by the end of the week. It's time this girl gets a nice new dress
I already have a quart of Butyrate, and a Pint of Nitrate and I have another pint of Nitrate and a pint of sanding sealer on the way from Sig with the Koverall. I'll be getting the colors (with the exception of the black I got from Sig) from Randolph because they had more shades to choose from, plus they have matching enamels for the cowl and wheel pants.
The cowl opening in the bottom, I had to cut it all the way back to make it easier to get the cowl on and off over the mounts. With the big bottom cut out and a 1 inch gap all the way around the firewall for cooling air, this thing should run cold!! lol
Bottom tail brace wire mounting bracket made out of .025" steel, I'll make the other 12 out of the same stuff after covering.
I used a Sig flex cable for the throttle, and the engine came with a B&B linkage. The cable was a bit of a pain to get rigged but once I got it it works slick as snot, best thing is it is all the way over to the side of the fuse and then curves back to the throttle at the end. This gives me PLENTY of room for the fuel tank and lines.
The servos are just for rigging purposes, when it's done it's getting Savox through out. I was going to get Pro Modeler, but I changed my mind lol.
The Randolph Color Chart
time to start thinking about covering! Also, just missing the aileron servos, battery and fuel tank I weighed the Krier the other day. 10 pounds!!!!!! That leaves me with 7 pounds to get it covered and finished to hit my target weight, I think I can do that lol
I matched the white to grampa's Skybolt and it is Randolph white. He literally had a 55 gallon drum of white dope so everything he built was the same shade. Therefore, my Krier will be Randolph white
After studying all of our pictures dad and I came to the conclusion that Madrid Red was the closest to what papaw had on his Krier Kraft. The other shades were to dark or had too much orange. Got a quart of each on the way!
It will be a week or two before I get to covering the Krier, after I finish up the last couple of details I'm going to bang out a Sig Kougar for my dad (it's already been started). Then he is going to cover it with Sig silkspan and it will then be the test/practice platform for masking and spraying the color dope. This way if there is a problem, I learn it on the Kougar and not on the Krier
I'll probably post pictures of both during the covering process.
Finally, for
and giggles I got to adding up what I have spent on this thing and was pretty shocked. Now granted, it's not everyday that you get a new in box Q35 for $90 (although we have 2 and dad just got a Q50 for the Skybolt for just over $100, THANKS EBAY!) but so far I have only spent $650, and with just servos and a battery to go, this thing will be flight ready for less than 1K......... I LOVE SCATCH BUILDING!
