3DHS 58" Edge 540
I did when I was out with Pontus and Tim yesterday, the PULL/PULL seems to be much better. My last flight after landing, I noticed that the left aileron was flapping around all alone as the servo arm had come off. I had ordered the Dubro HDs and just hadn't swapped them in yet. I think once I replaced the arms, I am going to trim it and see what happens. I did notice that the CG might also be a bit off. It was pulling to gear in KE yesterday so once I landed I did a quick check. When balancing on the wing tube, it goes tail down with a 6s 3300mah pack. It still was going to tail with a 4400mah in it. What is the correct balance point? I will need to pull the cowl to install some more velcro further up. Anyone else had issue with getting the battery up into the cowl on 6s with the Motrofly?
Pontus - much luck with the repairs!!
Josh, my advice on balance:
Don't focus too much on where it balances on the ground. Get it in the air, trim for level flight at 2/3rd throttle, then flip her over and fly inverted.
If the nose drops, she's nose heavy. If she climbs, tail heavy. Nothing: neutral.
My planes are setup for a pinch forward of neutral, but find what works best for you. And remember, you can always mix a little rudder to elevator for KE flight to fix the tuck if she still does it after you find your preferred balance point.
-G
zmonster97
Member
Here's me flying my 58" edge yesterday! Watch in HD.
[video=youtube;g2AywinICJ0]http://www.youtube.com/watch?v=g2AywinICJ0[/video]
dskuro95
Can anyone who owns a 58 edge tell me how far it is from the firewall to the outside of the hole in the cowl for the prop? I need to see whether or not I will need spacers.
Thanks
dskuro95
Thanks
Thanks
What motor?
