3DHS 70" Velox
I just received my APC props and they do not fit on the prop hub that came with motrofly motor. Do the props come in different sizes when the hub is concerned.
No, you'll need a prop reamer to enlarge the hole to the size of the standard 8mm hub
I am really frustrated maybe I bit off more then I can chew, I drilled the holes as in an earlier for the motorfly 4325-425 post in this thread and the motor is way off from the cowl. there is no adjustment so I guess somehow I must redo the electric motor box or buy a new one. it needs to be spaced forward and up. forward I can see but up does not look possible.
View attachment 20001View attachment 20002View attachment 20003
Paulie, can you post a photo of the firewall without the motor on it for me to see?
G
rcbirk21
i did the same thing on my velox. had to leave the spinner off that i had for it with how off my drilling was.
