Scale 50% Dalotel 165
All I can say is, "WOW"!!!! I've known a few tenacious souls in my life. You sir must have written the book on tenacity. To do something of this caliber and of this magnitude is far beyond most others comprehension. Looking forward to each and every picture.
This is the servo system I will be using for the retracts, one each wing
       http://www.servocity.com/html/spg7950a_standard_rotation.html
For those who might be interested... (Cuz I was), here is an article on the full scale DM 165. Curiously interesting....
http://www.epoxyworks.com/29/pdf/Resurrection_of_the_Dalotel.pdf
Patto
That was very much worth reading.  Very cool!!
thank you I appreciate the kind words,
Roger
wesley.
Are you using CA for your ribs? Also what are your thoughts on using yellow wood glue.  I am fixing to start a AMR kit and was thinking about using yellow on most everything.
at this point I'm using CA but just to make sure everything is good, once I am satisfied, I will reinforce the ribs with tiny wood corner blocks
As for carpenters glue, its excellent, it simply takes time to cure, also if you would need to glue for instance a sheet on top a sheet  the glue being evaporative in nature,  would take a long time to cure same with sheeting a foam wing, but with sticks , plywood and such, where the glued surface is not too big, it would be just fine,
wesley said
What about strength between the two glues?  I apologize if I'm messing ur thread up.
Don't worry, your not messing anything
As for the glue, if you are building a regular kit out of balsa ,  you can use CA on everything, just be sure all parts have good fit.
Lately I  being using thick CA from Gorila glue, , not the poly urathane but CA.  it is extremely good and strong
