Joshet89
Hey @Joshet89,
I noticed in your wing pictures you only had sheer webs on one side of the front main spar. Did you only get 12 WSW2's in your kit too? The reason I ask is that in my instruction book on steps 134 and 135 (I think), the pictures clearly show and call for sheer webs on the front and back of the spar all the way out to the wig tip (minus the last rib bay) . Of course, this means you'd need 24 WSW2's to have enough. What's more confusing is that in the parts diagrams in the front of the book, they only show 12 WSW2's.
Yea I only had the 12 (minus 2 I lost somewhere along the way DOH!!) So on the first wing I built the webbing was on the backside of the spar and I just rolled with it. On the second wing I had a lightbulb moment seeing where the webbing attaches to the leading edge piece that slides into the ribs so I put the webbing on the front of the spars on that one. Just to keep everything secure I cut 2 more webbing pieces and glued them to front of the spars on the first wing. After reading your post I sent a quick email over to the guys at AMR to see if they can clear it up!
Edit: I received an email from Michael at AMR and he said one side is enough. Can't say enough about their customer service in that I received a response from them in less than 15 minutes.
It felt good to have the time to work on it again. More to come soon, I promise.
moment when the wing and jig became one. Purely because I have had similar instances!
