Now you bring up batteries? what can a worms you gonna open next Joe! Been running LiFe (A123). Biggest advantage is how hard you can push them. The discharge rate is unreal, you can't load them enough to test a voltage drop, at least not with our equipment, so voltage drop is not a problem, so no d-cup or cricket (I kinda prefer a c-cup, but that is just personal preference) and you can charge them as fast as your charger is able to. Charge mine at 6a and takes about ten minutes for a full charge. They also have a very flat discharge curve, 6.6v all the way through, so no need for a regulator. Mine always stay balanced, the two packs are always within 50mah after charging both of them. Downsides, because you can't load them, there is not a good way to know if they have a good charge on them. You have to figure how many amps you use in a flight and figure how many flights before recharging. I get 5 flights on a 100cc and end up a little over half the pack used. they will stay at 6.6v until the very end and they drop off immediately, so there is no warning that you are getting low on charge. They are a bit heavier than lion/lipo.
