Krazy Kanuk
STAB FLYING WIRES
After reading on FG the build of The Beast, it was apparent that several people had a lot of trouble with their flying wires breaking.
I decided to try something different and to build a much stronger Flying Wire assembly.
I started off with a 2-56 rod that was threaded at one end, and I found a 2mm carbon fiber tube that had the I.D. that was the exact diameter of the un threaded portion of the 2-56 rod. I cut several notches into the wire and then assembled it together with J B Weld.
I was also able to find some yellow shrink tubing at the electronics store in Barrie that just barely fit over the clevis. The colour matches perfectly with the Solartex fabric. When I start to paint the fuselage the paint will bond much better to the shrink tubing.
I now have a rigid light weight system and one that looks more "scale like".
