As a general rule, most engines will require .004" per inch of bore diameter for intended ring end gap minimum. More extreme engine applications, where the piston and ring will experience excessive heat, it is recommended to use .005" per inch of bore diameter ring end gap minimum. Generally, when measuring ring end gap, it is most always better to have too much than too little; a tight ring end gap can potentially cause the ring ends to touch during operation, which may cause a failure.
on my dle 120 i matched the ring to the cylinder. This should be done for each multi cylinder engine.
i nearly filed .oo2" off one and left the other alone to get what i like. The engine is a stump puller.
