Bartman
Defender of the Noob!
I've cut room to double up the frame members where the loads go from the leading edge down into the fuselage sides.  If I can get good epoxy bonds and solid wood to wood contact I should be good.  I thought about some steel but figured some more wood would work.
It passed destructive testing today where I tried to pull it apart and probably applied thirty pounds of force against the bulkhead I glued in. I figured if it broke and went into the garbage it was saving me all of the time to finish it before it breaks apart anyway!
