IMAC Carden Pro 124 Build, My Dream Plane
ROLLERMAN
Hello all, now that I have the two fuse sides almost completed I went back to the engine box to install the F2 formers, while I had that to the side, I worked on the hard points where the canopy bolts on the fuse. I am so pumped to work on it every night, I’m enjoying every minute of it.
Hey LOOK, The best sanding block EVER.
tl3
what he's not divulging is this build was actually started 3 1/2 years ago... :congrats: ;)
... jk...looking good Primo
ROLLERMAN
LOL!!! I tell ya, I was kinda skeptical about building again, but I'm so glad I am, loving every minute of it. I have been kidding around with Wayne Mathews, He named his Dalton THE BITCH, mine will be EL CHUPACABRA.
I'll be out working on it soon. I plant to locate and glue the wing and stab sockets tonight. Pictures tomorrow. If everything goes well I hope to be covering by the end of May.
ROLLERMAN
Well, I did not get to glue the socket supports on, it was more like, how do I go about doing this without screwing something up. So, as you will see on the first picture the plans show an angle between F2 and the LE of the fuse sides, I want to get this done before gluing the stab and wing sockets. After staring at it and pondering about it for over an hour I came up with an idea on how to mark the fuse LE to have some kind of reference to be able to sand it. The pictures will do a better job explaining how I did it.
The last picture shows how it turn out.
ROLLERMAN
I jumped the gun just a bit, just a few pics of the engine box set up on the table. It just so happens that the long 90 degree angle bar is exactly 1/8 thick so I used this for my offset since it does not have the 1/8 balsa sheet glued on it yet.
