    Dismiss Notice
Covering questions
Discussion in 'Covering and Painting' started by Flyingjon, Jan 14, 2016.
  1. pawnshopmike
    pawnshopmike Staff Member
    Jul 27, 2014
    4,456
    4,055
    Sullivan Missouri
    I wouldn't worry about plugging the holes with a dowel. Just re-drill them with the correct size drill for the hinges. You don't want a super tight fit because it will push out all the glue when you insert the hinge. If you have any holes that are really oversized, plug them with balsa before drilling. If you plug them with a hardwood dowel you'll have a hard time re-drilling them without the drill walking off to the side.
    Flyingjon likes this.
  2. BalsaDust
    BalsaDust Moderator
    Jul 29, 2014
    2,734
    2,925
    Somewhere
    Mike you have tried the go 2 glue on hinge points???? I use it all the time on flat plate pinned hinges. Tried it on a hinge point and it pulled out but maybe I didn't use enough glue on it.
  3. pawnshopmike
    Jul 27, 2014
    4,456
    4,055
    Sullivan Missouri
    Yup. Used it on the last two planes I hinged. Robarts need lots of glue no matter the type. And you have to be careful not to push all the glue out when insert the hinge.
  4. stangflyer
    stangflyer I like 'em "BIG"!
    Aug 26, 2014
    5,880
    7,711
    Meridian, Idaho
    Hey, that's some pretty cool stuff. Shock resistant means no vibrated loose hinges. Water resistant means tail dunkin' worries are over, and temperature resistant means when you're flying so fast that your tail feathers are on fire...it won't come loose! Oh wait, that's "fire resistant". LOL..... I may have to give this a shot next time. Thanks Mike for the input....:way_to_go:
    pawnshopmike and Flyingjon like this.
  5. yakken
    yakken 100cc
    Aug 26, 2014
    830
    877
    Lemme tell ya sumthin, mr neil westdorp put my 37.5 yak threw full throttle hell yesterday and i am definitely a firm believer in gorilla glue. My flat hinges are glued in with it and they are not pinned.lol
    Sent from my SM-N910P using Tapatalk
  6. Pistolera
    Pistolera HEY!..GET OUTTA MY TREE!
    Aug 26, 2014
    1,696
    2,136
    Lumberville, PA
    Neil flies hard......nah....:lol2:
    yakken likes this.
  7. yakken
    yakken 100cc
    Aug 26, 2014
    830
    877
    How close are you to gettysburg? We have an awesome field there on a private farm we have been flying at a couple times a month.
  8. Pistolera
    Aug 26, 2014
    1,696
    2,136
    Lumberville, PA
    About 3 hours. Maybe less if it's on the east side of G'burg?
  9. Flyingjon
    Flyingjon 70cc twin V2
    Aug 26, 2014
    404
    348
    SW Kansas
    I've been dabbling with this thing when I get a chance in the evenings or over noon hour. I drilled all the hinge holes out and plugged them with a dowel. Then I marked the centerline carefully and drilled for new hinges. Now I'm sanding them down to match the bevel.
    [​IMG][​IMG]
    Some of the covering showed up today and I'm hoping the rest will be here by tomorrow.
    stangflyer, JAG, Alky6 and 4 others like this.
  10. Flyingjon
    Aug 26, 2014
    404
    348
    SW Kansas
    I'm trying my luck out by starting with the side force generators.
    [​IMG]
    pawnshopmike, Alky6 and ericrs like this.
