Yep! Bill Vargas is a good dude!
I flew the Dalton on Sunday. Motor needed a bit of work, but I got it running, but the low end and start up needs some work. But I have some time to do so. I'm going to start with tuning the L needle. If that doesn't change much of anything, then I'm going to go with the ignition system. If that doesn't help, I'm going to install a RCExl and sensor unit from Milton. Then, if that doesn't work, I'm gonna call Joe Lewis, or get with him and see what all he says.
But the engine turns the Falcon 31x10W at just shy of 6K. I know that there is more to get out of the engine. I had to rebuild the carb, while at the field. Fuel was pouring out of the carb, in which I thought it was the fuel metering needle. Well, I checked the metering needle, it moved but I didn't press on the needle itself. I replaced the front diaphragm while I was in there. Button it all up, and try to fire up again. Still, fuel pouring out of the carb. Just goes to show, go with your gut instinct! Pulled the metering needle out of it, and it was varnished up just a smidge. Cleaned it up, checked the backside, and installed new gasket and pumper. Well, good news, no fuel pouring from the carb, but still have the issue with the idle and start up. Small steps forward!!
Next time out, I'm gonna try the Mezzy 30x12.
