here is how I make the hard points....
sort of like a sandwich. there is 1/16th plywood, then there are 3/4" wide balsa stock, the central one is 1/4" thick, the outer sides are 1/2" thick. I use the horn as a gauge, then glue in using CA glue.
I will be making more than plenty, better to have left over than not enough... this is now glued on one laminate side only. still not ready to glue on other side.
Now, the exposed side is sanded smooth, now it is ready to glue on the last laminate.
just checking again that the thickness is appropriate...
here is the final product, still needs some final sanding. I will do this when i get home from work today. Then I will cut these and glue them in.
I do not know if you can picture this, but this is how the horn fits in. This will get glued into the foam and the LE of the elevator/aileron. IT will have a larger surface area to glue to balsa LE compared to foam with a round hard point.
