here is the header/canister configuration. I need to lengthen both headers by 1", then I should be real good. My throttle/choke linkage is awful close to the headers, but, it is what it is.
side view of the 2 in 1 headers...
plenty of room for the mounts, just waiting for them to get here. Once I install the mounts, then the fuselage can be covered.
I spoke to Tony, and he says, that both headers need to be same exact length, therefore, my hope of the stingers coming out together at same length is impossible. I will make stingers exit further back than the canister tunnel. I will have to construct a cover for this area, as well as sheet the floor. Should be fun. Due to the cylinders being staggered, there is not way the stingers can exit in same location distance from the front of the firewall.
Not enough length!!! Once i lengthen it by 1", I should be good. Should arrive next week.
Headers come real close!!! But it is what it is. I cannot switch headers from right to left, this will not work out. HAs to be this way.
