Hello Vern, thank you very much for your comments. However, I cannot take credit for it. This has been designed by others way before my time, and I have only copied them!! Also, yes, everything you have stated is true, the exit has to be at least 2 to 1, some say 3 to 1.
Well, I go overkill, and make it more so. DO not know if this hurts me.
May be increases my drag, do not know./
I also have a friend that has a sheet metal business, and he has cut for me some aluminum, which i use as lips under all my models, to help create an area of negative pressure, and thus, help extract the hot air out of the cowl/motor area.
In conclusion, as you have pointed out, to have a nice, healthy , happy motor, you need:
1. good oil
2. good needle settings
3. very good baffling
4. appropriate exit to inlet ratios, so that there is more area for air to escape than area where air goes in
5. create an area of negative pressure by using some form of "lip" (louvres) , that helps extract the hot air out.,
Here are some pictures for your enjoyment of how I overkill on this topic, but it shows in my telemetry. Most of my engines run well and have low temps, when the airplanes are set up like this.
