I just checked that...with the canopy line level the wing has a -1 degree of incidence...and I can't see that being what Delro intended...but this is assuming the canopy line represents the zero incidence line, and I don't think there is any reason it has to. Since you set the incidence of everything on this plane to your liking (firewall, tail, and wing) you can make anything you like be the master for setting incidence.Have you checked the factory set wing incidence against the canopy line?
That looks quality! Double bevel the STABS! Easy to do.
Do it! Post pics!
eAgreed!
The Delro's and Exclusiv Modelbau stuff was always really nice. I got to check them out pretty well when I worked at DA and always found they had some ingenious ideas on how to do certain things.
