BalsaDust
Ok seemed enough people where interested so I will start a build thread on the little profile I designed.
Based off of the Edge 540
44" span
40" lentgh
40-45 ounces
3542 outrunner
60amp esc
3S or 4S 2200mah lipo dependent on KV of motor and what size prop you prefer.
Pictures uploaded out of order but I have description under each one
Stab outer frame cut part.
Framework for inside of stab.
Elevator and stab all built. Need to sheet one side of the stab and then glue on tristock to both. Stab ends up 1/16" thicker than elevator is because of sheeting.
Just your normal looking rudder
Fuse cut parts just laid in place.
Cut parts right after coming off of the CNC machine.
Stab sheeted
Landing gear block option 2. If you plan to install landing gear you will want to laminate these two 1/16 ply parts to the outside of the 1/4 balsa core. I will not be using landing gear and will either catch or belly land in the grass those I'm just installing the 3/8" thick landing gear block instead.
3/8" tube cut to length and cut parts clamped to it. Do no I repeat do not glue the tube in at this time.
Close up of the clamp around the motor mount area. Another do no is no not glue to the motor mount. It still needs to be laminated with ply on both sides and will be the very last piece installed on plane when doing final glue up after it is covered.
Parts that have a larger gluing area I like to mark the edges and then run a bead of medium CA and glue in place instead of trusting that thin CA will get into the entire joint.
Servo rails in the tail of the plane. Pick which side you want your servos installed on. You can do the entire rail as bass wood but I prefer to first glue in a piece of 1/4 square balsa then laminate a piece of bass on top. I do it this way to keep as much weight out of the tail. I like to use wood glue for this as I feel CA doesnt hold to harder woods as well.
Here you can see both rails made up. I do hit the ends with a little thin CA.
Install all the vertical stringers and the fuse is done minus tristock on the rudder post and a final sand. Again note the tube and motor mount are not glued to anything.
Will post more tomorrow after I get more done.
44" span
40" lentgh
40-45 ounces
3542 outrunner
60amp esc
