3D Edge 540 Profile Build (Glitter JR)
Discussion in 'Giant / Scale Scratch and Kit Build Threads' started by BalsaDust, Feb 4, 2019.
  1. Snoopy1
    Snoopy1 640cc Uber Pimp
    4,263
    5,955
    113
    Canada
    Really enjoying this build really learning how these little planes are put together and how to make and build one.
  2. BalsaDust
    BalsaDust Moderator
    B85058D9-FE5C-4316-AC66-020487CCDBE7.jpeg Ok first let’s back track a second. Don’t won’t go forget this step as I have before and it’s a pain to correct once the wing is built. On a profile your receiver will be in the wing so you will need a way for one aileron servo lead to get to the other wing. Just use a dremel tool to grind down the tube hugger on one side even with the hole cut in the rib. You can do both sides if you want but it’s not needed.
    8FC8F7DB-E953-4DB8-9B0C-C556A9B9F24A.jpeg Next up we will prepare the spars. The spar is just 1/4” square balsa. Use harder balsa. Since I don’t have any 48” stock I have to splice two sticks together. A lot of people just do a 45 degree cut but I was taught that the splice should be twice as long as the thickness of the wood. This makes it 1/2” long. I just tape two sticks on top of each other, mark 1/2” back, draw a line, then take it to the scroll saw and cut it. A6934209-D858-4E72-B98A-57623BDC6419.jpeg After it is cut. Nice and clean and both pieces are even. F9C8371B-8891-4F96-8AA5-3A828777DAC4.jpeg Now put the two pieces up against a straight edge and line them up. I put a small dab of medium ca on it before sliding them together then once together I wick thin ca all around. 4462DC0E-859B-4800-BAF8-08CEC512F0DD.jpeg See nice clean and even. Now you can lay it over the plans and cut to length. I like to leave about 1/2” overhang on both ends. B8BBF581-D52F-410E-89FF-A2173DAB4394.jpeg Next you need to cut your rib doublers. You will need two and they span from R2 to R2. Use hard balsa or bass wood lay it over the plans and cut it so it goes past R2 on both sides by about 1/8”.
    95F4B035-F041-4BF7-BAA1-FB051DF4DFBF.jpeg Now grab your Center section, install the doubler first, then the spar itself. Make sure it’s seated fully. Since the ribs are router cut you made need to use a small file to square up the corners in spar notches as the router bit leaves them rounded. At this point only glue the the spars two the center section. Do not fully glue the doubler the full length. That needs to weight until all the ribs are laid out and the spars are pulled up to the prop angle of the wing. D7279D40-B237-44FE-9486-F5CE23A4107D.jpeg Lastly go ahead and lay it back down over the plans and square it up. At this point go ahead and cut the rest of the ribs free from the cut sheets and get ready to lay up the rest of the wing.
  3. BalsaDust
    BalsaDust Moderator
    CD5ECADA-7B79-4078-97D4-53B634A3167F.jpeg Ok step one once spar and center section are laid out. From the main spar to the le of the wing needs to be the exact width of the motor mount so I like to just slip the mount down in it until things start getting glued. 8F43FA86-7080-47C1-A07D-CAB7D46CA27E.jpeg Lay all your ribs out, make sure they line up with the plans, and that they are standing straight up and then hit them all with thin CA. Still do not wick in glue on the subspar to main spar joint. 097BE0BC-A4B3-4258-ABF8-BFD46CA35A04.jpeg Glue in the top sub spar. 18D1A865-7400-4E8D-AC7F-743A9761C5A5.jpeg Now lay in your top main spar. Once it is glued all the way around then go ahead and wick in a bunch of thin ca to the sub spar to main spar joint. Also note if you spliced sticks together like me then it’s best to let the splices be opposite of each other. Then end up falling on rib 4 so I let the bottom one be in the right panel and top one be in the left panel 9E0F4585-5B87-4332-8FBE-BDB5016BB582.jpeg starting to look like a wing. 297D9ECF-8FA1-4C4E-9426-5090995C83C9.jpeg 40E8ABB8-3B68-4035-AD6B-C3FE6F92C2BA.jpeg now let’s lay in the front sub spar. I use a medium density balsa hear. Be careful around you motor mount not to glue it in. 81266BB5-A20A-4258-B8CB-1EEA0A7C77AE.jpeg At this point since I use weights I remove a bunch of them since the structure is more solid now I do however move some to sit on top of the spar just helps keep in flat on the table also have some butted to the back of the spar keeping the le tight to the angle. 6F61DDBA-32A5-4A77-A81C-0A0A00180AEF.jpeg go ahead and glue on the 5/16x 1/4 TE stock now. FAB54B0D-3CCE-4373-AD97-FD3201EA8DBB.jpeg Forgot to draw these in cad but easily done using some of the scrap 3/32 from the ribs cut sheet. Just hold it underneath and trace the shape with a pencil. DA094279-E951-428C-AC34-6CCC2B7D582E.jpeg
    At the root 0074B588-BA36-494B-BD94-30DFAE3168AE.jpeg At the tip. Doing this really strengthens the wing to protect it in a dork. 2D2A2597-B125-4409-B4F1-13230FF0AA58.jpeg No go ahead and install the TE sheeting. It’s 1/16x3/4. Save the extra you cut off the ends as it’s perfect for doing cap strips on all the ribs.
    That’s all for now. Might be a few days before my next post. We have family staying with us for the weekend.
    WMcNabb, TonyHallo, Snoopy1 and 2 others like this.
  4. [​IMG]
    49dimes likes this.
  5. 49dimes
    49dimes Damn I'm hungry
    What's that arm chair Emoji saying ? lol
    pawnshopmike likes this.
  6. Snoopy1
    4,263
    5,955
    113
    Canada
    Throughly enjoying this cannot weight for the next instalment.
  7. BalsaDust
    BalsaDust Moderator
    1E8E0BEA-D9C9-41E4-9AA1-D3F81F0180F9.jpeg Couple of quick bits today. Servo mounts for the wing. You will need to grab these ply pieces. For these you have to grab a file and file the edges square or that won’t fit tightly. C8FC5531-DFD0-47CD-8EAF-431799C00761.jpeg Then just go to the outside of R2. Butt it up to the back of the spare and even with the top of the rib. Tack it all in with thin ca. Center section sheeting will go over top of this to tie it all together really well but I like to also flip the wing, run a bead of medium ca in the corners around it and fill with micro balloons. It will make a nice strong fillet.
  8. BalsaDust
    BalsaDust Moderator
    Well back in the flow of things and got a little work done this morning. First up was doing the LE sheeting. I just grabbed a sheet of 1/16”x3”x36” balsa and ripped it into four even 3/4” wide pieces. Mark the center line of the front subspar at each end and glue to this. I’m using softer balsa here so I was able to then just roll it over and glue it doen but if not just spray a little windex on it to help with the curve. The sheeting will overhang the LE of the rib just a bit bit that’s ok well will address that a little later. 6092E7A7-F9D6-4047-B08C-FB51249B05C7.jpeg After the le sheeting was done I moved onto the sheer webs. Again using 1/16 balsa 3” wide but I selected a little harder piece of balsa for this. I glue mine to the front of the spars and dont feel the need to fill the entire space, just be sure it’s flush to the inside rib. 1E5049B8-7940-4385-86E5-8EF7BF40BBB3.jpeg on the otermost bay do the opposite having the sheer web butt up against the outer tip rib. This makes the tip s little stronger in the event of a tip strike.
    Alky6, pawnshopmike, WMcNabb and 2 others like this.
  9. BalsaDust
    BalsaDust Moderator
    7F3AC313-9411-4C14-BBCE-B80E53915981.jpeg Now that all the sheer webs are done we need to start the sheeting on the wing. Mind you this is where i realizes I screwed up. No biggie it will be fine and I will do the other side the proper way. On this side of the wing it needs to be sheeted our enough to cover the servo mounts. This ties the servo mounts into the wing really well. 0D189278-ECB9-475A-9F45-8A53E86BA730.jpeg All I have is 3” balsa so I needed three pieces to fully cover it. Edge glue them up nice and sand the joints smooth. F3DE6332-7830-4BB7-8044-6F9B1D49CC8C.jpeg now it needs to be cut to fit between the le and TE. This is the mess up. Normally I install LE sheeting, then sheet the Center section, then the TE parts. It’s just a little easier that way. A26510C5-C3D6-43D5-BD88-54A9B64273A0.jpeg Lay it out where it’s going to be and then use a long straight edge butted to the front of the TE stock to then trace a line to cut on the sheeting. 0C6A8797-7EC1-4FDC-92C7-8F838B1E73CB.jpeg Look how pretty that is. 781FE72D-39F6-4F7D-9F61-81D341DE681D.jpeg For some extra strength I like the cut some scraps to glue under the TE. Works really well. ED37D5F8-B2CE-4E53-BE80-2139552731B3.jpeg now using your glue of choice glue it in place. Be sure to use lots of weights to be sure it is pressed down everywhere it needs to be. 19E8F6F3-836F-4EBD-BB3C-C81EF8BFFBEA.jpeg Now you should have scraps left over where the le and TE pieces where long. Do the tip rib cap strip with this. Again this is to put lots of strength into the tip of the wing. 77A33D8A-34F0-465A-AA01-64D80298DF73.jpeg Now cut some 1/4” wide strips to cap strip all the ribs. Next is total personal preference on wether or not you want to do cap strips on top of the main spar. Some people like the smoother look in the covering where it can sag between the ribs.
    F2AD0D77-FE70-436B-80E6-E9F6B687C690.jpeg Now the wing is ready to flip and start the other side.
  10. Snoopy1
    4,263
    5,955
    113
    Canada
    It is interesting that you do not sheet from the leading edge to the main spar. So as it is you must be ok with the stiffness of the wing.
