Back to the ailerons. These are really simple, but thought I'd touch on a little clamping technique as against all odds I've got a bit of experience in this small area
The long balsa sticks have quite a bit of bow in them. A lot in one direction and a little in another. (Nothing against the quality, the wood is perfect...it's just how wood behaves)
Getting rid of it is easy and I approached it the same way I would in woodworking. As long as it is glued up straight the tension between the stick and the sheeting should keep it straight. Glued up using the stick as the reference the sheeting (with next to no stiffness relative to the stick) will just follow the bow on the stick.
So I've got two straight references. The edge of the balsa sheeting combined with pins covers one direction of bow and the flat table combined with clamps covers the other.
So I let the table and clamps with their greater surface area and pressure deal with the more significant bow and the pins deal with the less significant bow.
The last choice is which side of the more significant bow to place against the sheeting/table. One side has the middle touching with the ends sticking up above the sheeting and the other has the ends touching with the middle sticking up above the sheeting. I like the second option.
Put some glue down on the stick and spread it evenly then pinned and clamped from one side to the other. Since there are curves to deal with it worked best to work from one side to the other. Simply aligned the edge of the stick with edge of the sheeting and pinned and clamped as I went.
