ThePledge
^Can't imagine doing a build without one after using it. Works exactly as advertised. Hobbylinc.com
Finished sanding the big balsa stick in the ailerons to match the line of the triangles. It was easier than I expected. Used a little 60 grit CA'd to about an 8 x 1in piece of ply. This let me hit the stick without hitting the triangles. The balsa sticks extend lengthwise out past the sheeting and this makes getting the angle at the edge of the sheeting easier by supporting the sanding stick.
Glued the opposite sheeting on the ailerons. Surprised to see this put a bow into the ailerons. Might have some to do with the water in the glue. Fortunately the bow disappeared after weighting them down on another flat table for a few hours. Needed to make room for the next ones. I bought a ton of rice and filled gallon bags about half way. Figured this was a better idea than messing around with sand as I'll eat the rice. The sheeting really stiffened the ailerons up.
Had some room on the table so I started the stabs. These are really easy with the miter sander. There's a nice picture included on the CD so I just cut the angles the same. Balsa sticks go on either side of the ply so I cut four at a time (one for each side of the two stabs) after measuring the angles. Got one stick perfect than cut out the other three in the miter box leaving about 1mm extra length than finishing with the miter sander. Worked in a circle pinning each stick and using the last one as a reference to get the angles and length right.
Edit; These pics are getting downgraded pretty severely by my phone --> computer transfer. I'll get them straightened out..
