Last night I squeezed the airplane back into my workshop and got it on the bench. I pulled the cowl off to make sure everything survived maiden day, and other than one Teflon coupler leaking just a bit it all looks great.
I need to add some down thrust so I spent some time figuring out just how I wanted to do it. I decided to take one of the plastic spacers that came with Blazing Star mount and sand it into an angled shim. I'm going to put it between the mount and the firewall, so that way the engine is still bolted to a nice flat piece of aluminum. Today at work I sanded the spacer and it turned out pretty good. I'm not sure how much down it will give me, but I'll try and check it tonight.
Stock Spacer
Sanded Shim.
I also have a nasty surge when flying level and steady half throttle. It's not a burble, but a surge like your moving the throttle that I need to deal with. It could be several things, starting with tuning. Other causes could be air flow/air pressure at the carb, or header length, and a few more things. It's more than likely tuning, but there is a big hole in the cowl right in front of the carb so it gets a lot of air blown right on it. The common fix for the air pressure problem is to put a fitting in the diaphragm plate and run a hole into the fuselage. Another fix I've seen is to add a flat plate in front of the diaphragm plate to keep the air from blowing right on it. My DA120 has the red aluminum diaphragm cover with the holes in the top and bottom which is supposed to help stop that problem. But as you can see, this carb gets a pretty big air blast.
Now I could close the hole in the cowl, but I don't want to for several reasons. It's how I set the choke, It's how I see the needles to adjust them, and it's a straight through flow for air to cool the cans. Now I know a lot of people say they should be closed to help the air flow for cooling the engine from the front of the cowl and the baffles, and they could be right, but I like to get more air flowing over the cans since they are directly under the fuel tank and the batteries. I am planning on adding more exit vents, since I think I don't have enough.
Tonight I'm going to make an aluminum plate that bolts on over the original diaphragm cover with some small standoffs. It will block the direct air blast from the holes in the diaphragm cover and hang low enough to keep it off of the choke blade and throat as well. Will this help the surge, maybe, if it's an air pressure thing, but chances are it's tuning. But since I like to make little things out of aluminum, and it 's free, and it wont hurt anything I'm going to build one.
Here is one that Richo from DA Australia posted a picture of.
Nice shim that is not easy to do and get flat on both sides. My question is now when you install the shim the spinner is going to be off. I have done this and then end up getting very frustrated trying to get the cowl centred again if you know how to do this an easy way please let me know. Because I have left engine alone just because it so difficult to correct the cowl . Thanks
