Some weight measure for what I believe will be the dry weight total for this plane.....
Fuse w/engine, prop, spinner, canopy/cowl and 14oz fuel tank= 10lbs 3oz
Large Pro flow, 2n1 header and coupler= 1lb 5oz
Wings and wing tube= 2lbs 14oz
Stabs w/elevators, stab tube and rudder= 1lb
Ignition, 5000mah flight battery (2s Lipo), switch and fuel dot= 1lb
6 HV HT digital servos and required extensions + receiver= 1lb
Hardware and servo arms= 8oz
Total= 17lbs 14oz.........Take off weight should be close to or under 19 pounds.
@ericb was getting 41 pounds thrust with same motor and prop (new) With his 20 pound EF 94 MXSR.
Ahhhhh! That coveted 2:1 thrust to weight ratio should be slightly exceeded!
where's da HEAT?
