Not a problem. I can give you an approximate as not all 40 centers are the same. The 40% 260 is a much smaller airframe, (Not much bigger than a 35% 330) than the 40% 330. The 40% 330 is larger than the 40 center Sukhoi. (Depending on manufacturer). The 40% Sbach is pretty close in size to the 330. The Edge somewhere in between. And of course the 40% Behemoth Yak is, well just plain big. So relative size of the full scale will ultimately dictate the size of their perspective 40% counter parts. Now as for weight, they are all fairly close to one another. But again, it would depend on setup. As well as construction techniques. 2 servos vs. 3. Straight extensions vs. Multi-plex harnesses, snakeskin or the like. All this being taken into consideration, my 40% Yak wings with 3 servos per each aileron, harnesses and wing tube are right at 11.5 pounds. My 260 were about 10 on the nose. The Hangar 9 Sukhoi with two servos per each aileron, harnesses and tube are 10.8 pounds. As for the 330? No clue yet but will get a weight once they are flight ready. In reality, anywhere between 9 to 12 pounds seems about right. Keep in mind Extreme Flight is probably lighter, and PAU Edge I know for a fact is pretty close and similar to my SD 260. Does this help or is ya confused?
Thanks for taking the time to do that for me. The reason I asked is that I am in the process of getting my big Stick back in the air and was putting the wing together and thought that it was very heavy. Weighing the wing assembly it came in at 12 lbs and 12 oz. it is on the heavy side but not outrageous. It does have a aluminum tube and is painted. I have been toying with the idea of building a 3D type of wing for it, just not sure if I am just throwing good money and a lot of work into a bad idea. Thanks for the help.
Lookin Good!
