Yeah, he's got 8 on the ailerons to my 6. We both have 4 on the elevators, but he has 4 on the rudder to my 3. Sure am glad he noticed the rudder tray mount. It's way better now!
Biting my lip......... Watching the flying being done with them, I am completely failing to see the reason for all those servos unless you have extremely flimsy control surfaces (or enormous thrust vectoring surfaces like Tavis). If the plane needs to be tail heavy to 3D and harrier around it has some serious design issues. I know that's the old school way of thinking when surfaces were small, airfoils were thick, servos were weak, voltage was 4.8-6.0 and planes were
h e a v y.......but planes set up like that can't draw a line in the sky worth a damn. When you convert that servo torque into lbs/sq ft and measure the square inches of surfaces area......then consider the weight of the plane itself that just does not add up and even common sense clearly shows a design flaw somewhere.
Sorry, guess I learned to fly about the time you took a break and this is just my $.02 in case there are any new guy's watching this thread.....tail heavy sucks. Tail heavy makes coupling for most people that don't mix the plane almost uncontrollable. Tail heavy also makes landing for less experienced pilots difficult and clumbsy. You will also find almost every major competitive pilot these days files their planes at somewhere between neutral or slightly nose heavy for XA to down right nose heavy for precision / 3D mix.
Sorry, just had to add my thoughts as this is driving me nuts when new guys look at these threads and think this is needed. You will always get better results with a good combination of wing loading, horsepower and mechanical setup as long as the plane is structurally designed well.
Again, sorry for the rant, just lots of guy's are impressionable and there are issues involved with flying heavy and tail heavy planes that need to be considered before trying it. 30-50cc planes (although very small) are the most popular size in the hobby closely followed by 35%'ish planes. If you fly a 30-50cc plane tail heavy many people will not make it past the maiden flight without needing garbage bags.
