Interesting how it actually dropped when you first put the load on it.What i do now is use a digital angle meter to set up throws on both servos with only one servo connected to the surface at a time. Once i have it dialed in i will line up the disconnected servo ball link to the horn or arm and match up the holes. Add subtrim where needed to correct neutral and end point to line up full defection. But i try to dial in the geometry so no trim is needed on end points. The hardware Joe is using works the best for this since you simply turn the screw to match full defection. I will use different servo arms and now unihubs to use as little as possible subtrim for neutral. Mid travel i will move the surface with the radio and look in the hole of the disconnected servo linkage to see if there is any misalignment. If there is, i will balance the midtravel in the radio. I found using an amp meter on brushless servos is not a good indicator of binding compared to coreless servos.
