Got a little work done on the lightening tonite.
Repositioned the power board under the fuel tray where the bottom access panel is. This is a little further forward to help with CG. Also, lengthen the wires and resoldered the deans connectors to allow for forward battery placement as Tim recommended.
Placed a piece of shock absorbing foam under the board, and attached it to the plane with a few tie straps.
![ImageUploadedByTapatalk1384315104.835204.jpg ImageUploadedByTapatalk1384315104.835204.jpg](https://www.giantscalenews.com/data/attachments/66/66169-3c366c487d69af23260907b74c01b265.jpg)
Plenty of length on power wires, and more room on the tray without the smoke tank.
![ImageUploadedByTapatalk1384315206.501364.jpg ImageUploadedByTapatalk1384315206.501364.jpg](https://www.giantscalenews.com/data/attachments/66/66170-8a59b1a278cda3aea8f60ea6278eacd9.jpg)
Also, removed the heavy smoke muffler, and installed the lighter factory muffler:
![ImageUploadedByTapatalk1384315242.100624.jpg ImageUploadedByTapatalk1384315242.100624.jpg](https://www.giantscalenews.com/data/attachments/66/66171-7a88bb824b26bed6a74e9b46b6056dd2.jpg)
Next up, reroute the wires to the underside, and close up this lighter plane.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
