AKfreak
I have a question to see if I have been doing this right, let's say you have to install a rudder servo control arm one tooth off because it won't center up mechanically, do you leave it and center the rudder with the cables, or do you use subtrim, and do it in the radio.
On the. JR 11x when you use subtrim, it affects the maximum deflection on the side that was corrected. That is to say that one side will deflect more than the other, because the center point has changed.
I always use subtrim to center the servo control arm and deal with mismatch of max deflection.
So what do you do?
So what do you do?
