Decal Dennis
TEAM EP&G
Nice Dennis! Looks great!
Thanks Mike
Interesting to see how thick the AJ Laser wing is.....
So how does a plane like this perform a slow roll without any input other than aileron? What keeps the nose up as you roll to KE?
Laminar airflow wings?
Lofted Fuselage?
Side exiting exhaust?
Precession should only come into play if you are using the elevator or the rudder. Rolling a plane should not cause any precession?? Maybe if you roll left you could bump the throttle at 90 degrees so as to gain a little upward pull of the nose from the fact that the motor is angled to the right?
Please explain how rolling causes any precession at all. I get that if you had precession occurring while rolling right, you could then goose the throttle a bit to increase the precession. But I don't get how your going to induce any precession without adding rudder or elevator?
As far as the design, I know the fuse was relatively tall and narrow, creating a flat side.
