 Im ok on building upside down bit messed up on the laminate sequence so had to make a # 3 rib but glad i caught it before I did the other 3 & 4  ribs..Worked on it today and got a lot of the wilg finished but at a point Im not sure about. It says put shear webing lanels butween the upper and lower wing spar and the plans indicate P406W25 but cant find anything that corresponds to that. Do you just cut them out of 1/16 Balsa stock? I.m afraid to start cutting without knowing I'm using the correst panel. I might just go over to my warehouse and see if I have some 1/16th stock.
