I think TBrum was running 14.5 inch headers with the ES pipes.
The engine might be a little more prone to getting hot if the headers are shorter than the peak RPM length.
Hows the midrange compared to mufflers?
Other than sound, not a lot of difference from mufflers, biggest gains are on the very low and up through the middle. The "punch" was a lot more DA120'ish. There is no "peak" as the RPM remains glass smooth throughout.
I will say I was able to get similar RPM's to what Tbrum was getting but it is so close to the edge of lean tuning I would never run my engine that way with how I fly. If I was floating around and doing an occasional upline then maybe but if you want to use the power you don't want to tune to those RPM's he's posted.
You are correct. my headers are 14.5 plus about 1/4" gap in the coupler, I forgot.
If you are going to run mufflers you can't beat the J&A muffs that Joe has for this engine. Second best option would be Jtec DLE111 mufflers but the front is not slanted enough for many cowls.
. All fixed.....for next time. I've got a little more than 8 gallons through mine now and it's crazy smooth and reliable. Hope you get your's dialed in as well Bunky!!! (I know you will)
