Diggity
Awesome! That is how I was expecting to see it. Only question is on the top of the rudder is the wire bent at a 90 degree then recessed in the top of the rudder or bent 90 then another 90 with the point of the wire going down into the top of the rudder? One other question...are you the one running the new DLE-61 in your 92" Edge? If so how do you like the engine? I'm kind of between a DA60 and DLE61 for my next 30% build. Thanks!
The wire is already pre bent at 90 degree. There is only 1 bend in the wire at the top. Then it slides down the hole at the top of the rudder, then sets down nicely in the pre cut grove. I'm running the new DLE 61 and I am very impressed thus far. Unfortunately the weather here has not let me fly it again since the maiden day. I have 6 flights and the power right out of the box is equal to the da60. It idles quiter and smoother than the da60. I believe the weight comparisons are nearly the same between the two. The bolting pattern is totally different and off course the price between the two are miles apart.
