The Blue Wonder will fly a Crack Yak but there are much better motors out there now. I prefer the Crack Series 26 gram on the Crack Yak.
The Laser rolls a little differently than the Crack Yak. It has a faster roll rate that is not as affected by throttle as much as the Crack Yak. With the Crack Yak, increasing the throttle will have a large effect on the roll rate, and increasing airspeed will have a smaller effect. With the Laser, increased throttle will slightly increase the roll rate, and increasing airspeed will greatly increase the roll rate. For me, this makes the plane more predictable even though it rolls faster.
The 3114 is a great servo but it could be your problem. The recommended Twisted servo has a good bit more torque. If you want to use a Futaba servo for the ailerons of this plane, use the 3156. Also make sure your hinges move freely (not too much welders reinforcement, right?).
