wedoitall
Member
Don't apologize or feel stupid. We all learned by asking questions or reading about this stuff.
yea but you would think of all the 3d manuveurs i can do , i should be able to set my plane up right. just like if you can takeoff and fly 3d you should be able to land proper.
However, that firewall looks kinda fishy. Was there a rebuild done? If the front end isn't aligned properly, it could cause the thrust angle to be off, but you could mix that out on your radio.
how do i do that? a throttle to rudder mix?
i didnt notice it till today, the firewall. but no rebuild. i know exactly when the guy bought it and im pretty sure the flights flown on the airframe so far are around 15. pretty sure that firewall is a manufacturing defect. LOL, im sure ill get some flak for saying that, being these are laser cut and all. but i have another plane i bought new that i had to modify the antirotation pin and holes to get the wing to seat right.
Any chance something is loose in the bird? This might change both vertical and lateral CG.
Is it consistent in its negative effects? What I mean is: is whatever bad consistently there or is it there and gone again?
I agree that servos could be the problem, I ran HS-55's in a plane once and couldn't control it in 3D I switched to HS-65hb's and it was like a whole different plane. I could not believe the difference that it made.
i have everything bolted down really good. everything is both velcro'd and strapped or zipped tied down. im gonna move cg back closer to neutral and try it again. and maybe check lateral. the Emax that the guy used before are the same size as my 5245's may try those LOL. if a didnt live in the daggone boonies, id just run to a hobby shop and get me some servos. the closest one is 1.5 hr drive and they dont carry 85mgs. the 85 i have now is weird at center its solid but at full up theres some slop and full down theres alil play.
have any of you just bought the gears and changed them yourself?
