Aerobeez 88" Slick 540 v2 (50cc)
What does [MENTION=2215]Aerobeez[/MENTION] or [MENTION=2579]Pete[/MENTION] recommend?
njswede
By the way.... I remember reading somewhere that the Aerobeez 50cc planes had weak landing gear. Well, I deadsticked mine yesterday and ended up doing a VERY had landing. Not a scratch on the plane. [MENTION=283]AeroHeadTW[/MENTION] was standing next to me and was ready to bring out the garbage bags...
Pete
Does anyone have a tip for getting the elevator servo wires away from the pull-pull wires? I noticed my wires had some rub-marks from rubbing against the pull-pull. Eventually, the insulation will fail and short the wire, which would probably lead to a total loss...
I'm thinking of biting the bullet and opening the covering in the tail and somehow tie the wires up. Any better ideas that don't involve surgery?
On the inside of the fuselage you will see a channel area where you can run the elevator servo wires up and through. Once you have it through the first of the channels, run the wires continous to the front. I have mine rought up and away from the Pull/Pull cables first then to the front. Please let me know if you have any more questions!
Regards,
Pete
3dmike
By the way.... I remember reading somewhere that the Aerobeez 50cc planes had weak landing gear. Well, I deadsticked mine yesterday and ended up doing a VERY had landing. Not a scratch on the plane. @AeroHeadTW was standing next to me and was ready to bring out the garbage bags...
That's awesome to hear it held up to a controlled crash. :)
Regards,
Pete
Thanks for the quick reply Pete :)
That's often the way I do it on my planes without the tubes doing down the fuse.
Pete
Anytime GYRO! I'm trying to be more involved on these boards. Just so busy and at times, hard to get on here.
njswede
If you look really close on the landing picture, you'll see that the elevator halves have different deflection. The port one was unplugged at that point. I'm surprised how well it flew on one elevator half!
