Let me know when you have one for the opto 155A.
i’m really enjoying the MOTROLFLY DM-5335 motor with the ztw 150 esc but on two occasions i have lost timing. both times were right on take off when someone “punched “ the throttle. both times i had a low idle rpm set and when the throttle was punched everyone hear a loud screeching sound. if the throttle is dropped to zero and then replaced in a slower fashion everything is fine. i really can’t seem to simulate it with static testing but it has me worried because if it happens when punching out of a hover it will result in a crash. so far i have increased my low idle rpm which someone suggested to help it maintain timing. the other thing i’m considering is changing the timing on the ztw from the default auto setting to either high or low timing which are the other two choices. i was wondering if anyone had tested those settings and could tell me before i try it. if not i’ll try it and let you guys know the results.
wow,what a bummer. i built a sig smith mini and have a build thread over at wattflyer. i used the ztw gecko 85ampesc with a eflite power 46. the motor cogs with quick motor throttle. i just purchased this ztw through altitude hobby and am glad to have found this thread when i googled "ztw gecko problems" and see they are actively pursuing a correction to the problem. i must say,if it has this on going problem i wish i hadn't bought in nov when it was not performing properly with the motofly motors.
add eflites to the problem. i really am glad when i first heard the cog during the second flight it survived for further bench testing. the gecko esc programing card works great. to bad it was another $16 expense i would have not needed if i spent the extra $40 to use a castle ice like i have in all my other larger birds in the hanger.....i just figured ZTW was worth a try. hope to hear a email reply from altitude monday. stu
I have the Gecko 85A/MF 4315 combo in my 57 Extra and it works great, but the 150HV/MF4330 does not work correcty, such a mystery and want a nightmare for Altitude Hobbies and ZTW. I feel bad for Altitude.
The firmware Tim sent for the 85A Gecko fixed my issues with the MF I would imagine it it will fix your issues with the eflite, symptoms sound the same.
